跳转到主内容
Sony Alpha SLT-A55V LCD Display Replacement
你所需要的
  1. Sony Alpha SLT-A55V LCD Display Replacement, LCD Display: 步骤 1 中的图像 1,2 Sony Alpha SLT-A55V LCD Display Replacement, LCD Display: 步骤 1 中的图像 2,2
    • The LCD screen is located on the back of the SLT-A55V.
    • The screen folds out and can be rotated to view in several orientations.
  2. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 2 中的图像 1,1
    • Start the replacement by removing the rear cover of the camera.
    • The rear cover is attached with several screws on four sides of the camera. On the left side there are two screws near the clip for the wrist strap.
  3. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 3 中的图像 1,1
    • On the same side as the previous step lift the rubber flap that covers USB and the HDMI ports.
    • Remove two screws.
  4. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 4 中的图像 1,1
    • Remove three screws from the right hand side of the case.
  5. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 5 中的图像 1,1
    • Remove the screw that attaches the focusing adjustment for the eyepiece. The focusing wheel will also be removed.
  6. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 6 中的图像 1,1
    • On the bottom of the camera remove seven screws indicated by the circles in the picture to the left.
  7. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 7 中的图像 1,1
    • On the top of the camera there is a black plastic sticker that hides two screws which must be removed.
    • This sticker can be re-used. Peel the sticker off and place it on a clean piece of parchment paper or wax paper. This will prevent dirt and dust from getting on the adhesive.
    • Remove the two screws that lie beneath the sticker. The arrows indicate the location of these screws.
  8. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 8 中的图像 1,1
    • Using a nylon spudger, gently pry the cover open.
    • To do this step properly without damaging the back cover it is necessary to pry open the cover incrementally around the perimeter of the case.
  9. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 9 中的图像 1,1
    • After the cover has been opened, there are two ribbon cables connected to the back cover. These cables will be removed in the next step.
  10. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, gently remove the ribbon cables.
  11. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 11 中的图像 1,1
    • Unplug the ribbon cable indicated by the arrow on the left of the picture.
    • The arrow pointing to the black area indicates another sticker. This sticker will need to be removed in order to thread the ribbon cable through the back cover. This cable is attached to the LCD panel.
  12. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 12 中的图像 1,2 Sony Alpha SLT-A55V LCD Display Replacement: 步骤 12 中的图像 2,2
    • Using a nylon spudger, separate the LCD case the same way the main housing was separated.
  13. Sony Alpha SLT-A55V LCD Display Replacement: 步骤 13 中的图像 1,1
    • Unplug the ribbon cable from the LCD screen.
    • Replace the LCD screen and re-assemble in reverse order of these steps.
结论
2等其他人完成本指南。
Sultan Almunif
于09/26/15注册
357 声望
创作了3篇指南
团队
IUPUI, Team 1-1, Wilson Fall 2015 IUPUI, Team 1-1, Wilson Fall 2015 的会员
IUPUI-WILSON-F15S1G1
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 34
总计 3,266
