简介
For this guide you will be replacing the LCD screen as a unit. It is sold as an electronic assembly including an electronic board, connecting ribbon and the screen itself. To replace this part you will need precision set of screw drivers, and a set of plastic opening tools to "pop" open the clips.
We have not found an inexpensive supplier for this part. It may be cheaper to purchase a used or broken SLT-A55V for parts.
你所需要的
The LCD screen is located on the back of the SLT-A55V.
The screen folds out and can be rotated to view in several orientations.
On the top of the camera there is a black plastic sticker that hides two screws which must be removed.
This sticker can be re-used. Peel the sticker off and place it on a clean piece of parchment paper or wax paper. This will prevent dirt and dust from getting on the adhesive.
Remove the two screws that lie beneath the sticker. The arrows indicate the location of these screws.
2等其他人完成本指南。
