跳转到主内容
加入维修社区 - 创建账户
Sony Alpha NEX-6 Lens-release Button Replacement
你所需要的
  1. Sony Alpha NEX-6 Lens-release Button Replacement, Finding the Release Button: 步骤 1 中的图像 1,1
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
    添加评论
  2. Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: 步骤 2 中的图像 1,2 Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: 步骤 2 中的图像 2,2
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
    询问修复机器人
    添加评论
  3. Sony Alpha NEX-6 Lens-release Button Replacement, Lens Mount: 步骤 3 中的图像 1,1
    • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
    • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
    • The outer lens mount ring can now be removed.
    询问修复机器人
    添加评论
  4. Sony Alpha NEX-6 Lens-release Button Replacement: 步骤 4 中的图像 1,3 Sony Alpha NEX-6 Lens-release Button Replacement: 步骤 4 中的图像 2,3 Sony Alpha NEX-6 Lens-release Button Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Pay attention to the positioning of the spacer rings for reassembly.
    • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
    • Repeat this step for the second (silver) spacer ring.
    • The third image is what the camera should look like after all spacer rings are removed.
    询问修复机器人
    添加评论
  5. Sony Alpha NEX-6 Lens-release Button Replacement: 步骤 5 中的图像 1,2 Sony Alpha NEX-6 Lens-release Button Replacement: 步骤 5 中的图像 2,2
    • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
    询问修复机器人
    添加评论
  6. Sony Alpha NEX-6 Lens-release Button Replacement, Lens-release Button: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • By using tweezers, carefully remove the lens-release button by lifting upward.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Clayton Dale
于01/20/15注册
1,067 声望
创作了7篇指南
团队
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G2
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 72
总计 1,854
