跳转到主内容
加入维修社区 - 创建账户
Sony Alpha NEX-6 Lens Replacement
  1. Sony Alpha NEX-6 Lens Replacement, Finding the Release Button: 步骤 1 中的图像 1,1
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
    添加评论
  2. Sony Alpha NEX-6 Lens Replacement, Removing the Lens: 步骤 2 中的图像 1,2 Sony Alpha NEX-6 Lens Replacement, Removing the Lens: 步骤 2 中的图像 2,2
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
    询问修复机器人
    添加评论
结论
The procedure to disassemble this lens is different from reassembly. This guide encompasses both processes.
取消:我没有完成这个指南。
2等其他人完成本指南。
Clayton Dale
于01/20/15注册
1,067 声望
创作了7篇指南
团队
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G2
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 51
总计 3,114
