简介
The E-mount, the interface between a camera body and a lens, can be easily replaced when it's time to change a dented or non-functioning E-mount. E-mount is also referred to as a lens mount when the camera it is attached to has an interchangeable lens.
你所需要的
Unscrew the 4 silver 1.2 mm Phillips #000 screws along the front outer lens mount.
Detach the outer lens mount ring.
即将完成!
结论
