跳转到主内容
Sony Alpha NEX-5N E-mount Replacement
你所需要的
  1. Sony Alpha NEX-5N E-mount Replacement, E-mount: 步骤 1 中的图像 1,2 Sony Alpha NEX-5N E-mount Replacement, E-mount: 步骤 1 中的图像 2,2
    • While completing this guide, do not touch the image sensor (the center rectangle encircled by the lens mount).
    • Unscrew the 4 silver 1.2 mm Phillips #000 screws along the front outer lens mount.
    • Applying extra force to unscrew these 4 screws may be necessary.
    • Detach the outer lens mount ring.
  2. Sony Alpha NEX-5N E-mount Replacement: 步骤 2 中的图像 1,2 Sony Alpha NEX-5N E-mount Replacement: 步骤 2 中的图像 2,2
    • Pay attention to the positioning and order of the spacing rings for reassembly.
    • Using your fingers, pull out the first black spacer ring.
    • Repeat the previous step for the second silver spacer ring.
  3. Sony Alpha NEX-5N E-mount Replacement: 步骤 3 中的图像 1,3 Sony Alpha NEX-5N E-mount Replacement: 步骤 3 中的图像 2,3 Sony Alpha NEX-5N E-mount Replacement: 步骤 3 中的图像 3,3
    • Unscrew the 2 silver 1.2 mm Phillips #000 screws on opposing sides in the lens ring area.
    • Using your fingers, easily pull off lens housing. This will complete the removal of the E-mount.
    • The lens release button and the small spring underneath will be loose.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 1,300
