跳转到主内容
加入维修社区 - 创建账户
Sony Alpha ILCE-6000 Screen Replacement
你所需要的
  1. Sony Alpha ILCE-6000 Screen Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Turn off the camera by sliding the power switch to OFF.
  2. Sony Alpha ILCE-6000 Screen Replacement: 步骤 2 中的图像 1,3 Sony Alpha ILCE-6000 Screen Replacement: 步骤 2 中的图像 2,3 Sony Alpha ILCE-6000 Screen Replacement: 步骤 2 中的图像 3,3
    • Flip the camera upside down and locate the battery compartment.
    • Slide the compartment lock to OPEN to unlock it.
  3. Sony Alpha ILCE-6000 Screen Replacement: 步骤 3 中的图像 1,2 Sony Alpha ILCE-6000 Screen Replacement: 步骤 3 中的图像 2,2
    • Locate the blue lever that keeps the battery in place.
    • Push the blue lever back to release battery.
  4. Sony Alpha ILCE-6000 Screen Replacement: 步骤 4 中的图像 1,1
    • Once the battery is free, you are able to take the battery out of the compartment.
  5. Sony Alpha ILCE-6000 Screen Replacement, Screen: 步骤 5 中的图像 1,3 Sony Alpha ILCE-6000 Screen Replacement, Screen: 步骤 5 中的图像 2,3 Sony Alpha ILCE-6000 Screen Replacement, Screen: 步骤 5 中的图像 3,3
    • Flip the camera to the bottom side. Using screwdriver, remove the two screws located on the bottom of camera screen.
    • Flip the camera back over, locate the two other 3mm screws behind the screen and remove them.
  6. Sony Alpha ILCE-6000 Screen Replacement: 步骤 6 中的图像 1,1
    • Gently pry open the screen backplate.
  7. Sony Alpha ILCE-6000 Screen Replacement: 步骤 7 中的图像 1,2 Sony Alpha ILCE-6000 Screen Replacement: 步骤 7 中的图像 2,2
    • Gently pry off the plastic cover at the top of the screen.
  8. Sony Alpha ILCE-6000 Screen Replacement: 步骤 8 中的图像 1,2 Sony Alpha ILCE-6000 Screen Replacement: 步骤 8 中的图像 2,2
    • Carefully remove the clip located at the top of the screen.
  9. Sony Alpha ILCE-6000 Screen Replacement: 步骤 9 中的图像 1,1
    • Flip the camera so that it is bottom side up. Pry off the inner support plate.
  10. Sony Alpha ILCE-6000 Screen Replacement: 步骤 10 中的图像 1,3 Sony Alpha ILCE-6000 Screen Replacement: 步骤 10 中的图像 2,3 Sony Alpha ILCE-6000 Screen Replacement: 步骤 10 中的图像 3,3
    • Gently wiggle the screen's ribbon cable until it comes free from the white slot.
  11. Sony Alpha ILCE-6000 Screen Replacement: 步骤 11 中的图像 1,1
    • Pry apart the metal backplate and remove it.
  12. Sony Alpha ILCE-6000 Screen Replacement: 步骤 12 中的图像 1,2 Sony Alpha ILCE-6000 Screen Replacement: 步骤 12 中的图像 2,2
    • Gently remove the old screen, and replace it with the new one.
结论
7等其他人完成本指南。
Tony Au
于02/02/17注册
423 声望
创作了2篇指南
团队
UW Tacoma, Team 1-4, Rose Winter 2017 UW Tacoma, Team 1-4, Rose Winter 2017 的会员
UWT-ROSE-W17S1G4
4 名成员
创作了10篇指南
4指南评论
This is super helpful! Where did you purchase your replacement part from?
Claire Sweet - 回复
The white connector opens by prying up the black part. What about the little black connector?
Christopher St.Louis - 回复
Just comes out when you pull on it gently
Kevin Ketelaars -
Top left screw on back plate is a pain to put back in at an angle with magnetized JIS driver. Non magnetized or slightly loose fitting driver might help.
Trick is to get the screw fit in the thread at the right angle, then drive it in with the driver at an angle.
Kevin Ketelaars - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 108
总计 12,401
