跳转到主内容
Sony Alpha ILCE-6000 Lens Replacement
你所需要的
  1. Sony Alpha ILCE-6000 Lens Replacement, Lens: 步骤 1 中的图像 1,1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 Lens Replacement: 步骤 2 中的图像 1,1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 Lens Replacement: 步骤 3 中的图像 1,2 Sony Alpha ILCE-6000 Lens Replacement: 步骤 3 中的图像 2,2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
结论
Vuong Nguyen
于02/02/17注册
122 声望
撰写一个指南
团队
UW Tacoma, Team 1-4, Rose Winter 2017 UW Tacoma, Team 1-4, Rose Winter 2017 的会员
UWT-ROSE-W17S1G4
4 名成员
创作了10篇指南
一条评论
my camera will not recognize my lens, optical steady shot 1650. it used to work fine, but I dropped it. now the camera says it's not attached properly. any suggestions?
Connie - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 35
总计 1,966
