跳转到主内容
Sony Alpha ILCE-6000 E-mount Replacement
你所需要的
  1. Sony Alpha ILCE-6000 E-mount Replacement, Lens: 步骤 1 中的图像 1,1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 E-mount Replacement: 步骤 2 中的图像 1,1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 E-mount Replacement: 步骤 3 中的图像 1,2 Sony Alpha ILCE-6000 E-mount Replacement: 步骤 3 中的图像 2,2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
  4. Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: 步骤 4 中的图像 1,2 Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: 步骤 4 中的图像 2,2
    • Locate the E-mount on the front of the camera
  5. Sony Alpha ILCE-6000 E-mount Replacement: 步骤 5 中的图像 1,3 Sony Alpha ILCE-6000 E-mount Replacement: 步骤 5 中的图像 2,3 Sony Alpha ILCE-6000 E-mount Replacement: 步骤 5 中的图像 3,3
    • Take a Philips head 00 screw to remove the four of the 5.1mm screws located on the E-mount.
  6. Sony Alpha ILCE-6000 E-mount Replacement: 步骤 6 中的图像 1,3 Sony Alpha ILCE-6000 E-mount Replacement: 步骤 6 中的图像 2,3 Sony Alpha ILCE-6000 E-mount Replacement: 步骤 6 中的图像 3,3
    • After removing the screws, pull off the E-mount metal ring gently and wiggle it until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the metal piece that is located behind the plastic ring.
  7. Sony Alpha ILCE-6000 E-mount Replacement: 步骤 7 中的图像 1,1
    • Replace the plastic E-mount ring with a new one.
结论
Yirga Yilma
于02/02/17注册
221 声望
创作了2篇指南
团队
UW Tacoma, Team 1-4, Rose Winter 2017 UW Tacoma, Team 1-4, Rose Winter 2017 的会员
UWT-ROSE-W17S1G4
4 名成员
创作了10篇指南
2条评论
Hello folks,
actually I have to replace the E-mount ring my ILCE-6000, which seems very easy with this description. Thanks a lot for this!
Is the ring available anywhere on this globe? I would truly appreciate any hint.
Best regards, JDK
JDK - 回复
Hi there, found a source for the ring as original part. The price is reasonable. Now waiting for delivery ...
Best regards, JDK
JDK - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 76
总计 3,639
