跳转到主内容
Sony Alpha DSLR- A850 Focus lens Replacement
你所需要的
  1. Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: 步骤 1 中的图像 1,3 Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: 步骤 1 中的图像 2,3 Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: 步骤 1 中的图像 3,3
    • Push in the button next to the lens.
    • While holding the button twist the lens counter-clockwise.
    • Pull up and remove lens from camera.
  2. Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 2 中的图像 1,3 Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 2 中的图像 2,3 Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 2 中的图像 3,3
    • Inside toward the top you will find a small slit in the plastic piece.
    • Insert a flat head screw driver into the slit and pull down to access the focus lens.
  3. Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 3 中的图像 1,3 Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 3 中的图像 2,3 Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using tweezers grab the focus lens on the side by the two tabs that are on it.
    • Do not grab the focus lens in the middle as this will damage the lens.
    • Pull out and remove focus lens from camera.
  4. Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 4 中的图像 1,3 Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 4 中的图像 2,3 Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 4 中的图像 3,3
    • When inserting new focus make sure to orient it where the two tabs are facing towards you with the smaller tab facing up.
    • Angle the focus lens to make installation easier.
    • Lay the new focus lens into the plastic tray.
    • It does not snap into place.
  5. Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 5 中的图像 1,2 Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 5 中的图像 2,2
    • Insert screw driver into the slit and push up to close.
    • You can also use your thumb, if you are careful not to touch the lens as this could leave a smudge on the lens.
    • You will hear a click when the plastic tray is back in place.
  6. Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 6 中的图像 1,2 Sony Alpha DSLR- A850 Focus lens Replacement: 步骤 6 中的图像 2,2
    • When re-installing the lens line up the orange dots that are one both lens and camera.
    • Fit lens into place and turn clockwise to secure it back to camera.
结论
You have now completed a focus lens replacement.
Walter Littlefield
于03/21/18注册
265 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 17
总计 766
