跳转到主内容
Sony Alpha A350 Motherboard Replacement
你所需要的
  1. Sony Alpha A350 Motherboard Replacement, Front Case: 步骤 1 中的图像 1,2 Sony Alpha A350 Motherboard Replacement, Front Case: 步骤 1 中的图像 2,2
    • Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
    • Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
  2. Sony Alpha A350 Motherboard Replacement: 步骤 2 中的图像 1,2 Sony Alpha A350 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove one 3.6mm screw on the left side of the camera.
    • Open the remote / DC under the rubber flap to reveal a screw.
    • Using the Phillips #00 screwdriver, remove one 4.3mm screw.
  3. Sony Alpha A350 Motherboard Replacement: 步骤 3 中的图像 1,2 Sony Alpha A350 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Open the flash on the top of the camera and remove two 4.3mm screws with a Phillips #00 screwdriver.
    • If the spring guard falls out during deconstruction, gently place the guard over the spring during construction.
    • To open the flash, simply press the button on the left side.
  4. Sony Alpha A350 Motherboard Replacement: 步骤 4 中的图像 1,2 Sony Alpha A350 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Open the plastic SD card door.
    • Using Phillips #00 screwdriver, remove two 4.4 mm screws outside and two 4.4mm screws inside the door.
  5. Sony Alpha A350 Motherboard Replacement: 步骤 5 中的图像 1,2 Sony Alpha A350 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Gently pull the outer front case from the camera.
    • It should fall apart easily if all screws are removed.
  6. Sony Alpha A350 Motherboard Replacement, Eye Cup: 步骤 6 中的图像 1,3 Sony Alpha A350 Motherboard Replacement, Eye Cup: 步骤 6 中的图像 2,3 Sony Alpha A350 Motherboard Replacement, Eye Cup: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    购买
    • Identify the bottom of the eye cup
    • Using the heavy duty spudger, push the eye cup upward to remove it from the camera body.
  7. Sony Alpha A350 Motherboard Replacement: 步骤 7 中的图像 1,3 Sony Alpha A350 Motherboard Replacement: 步骤 7 中的图像 2,3 Sony Alpha A350 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Using the Phillips #000 screwdriver, unscrew the two screws from the eye cup.
    • Remove the back side of the eye cup.
  8. Sony Alpha A350 Motherboard Replacement: 步骤 8 中的图像 1,3 Sony Alpha A350 Motherboard Replacement: 步骤 8 中的图像 2,3 Sony Alpha A350 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Push down on the hard plastic part of the eye cup and remove it from the cushion.
  9. Sony Alpha A350 Motherboard Replacement, Rear Case: 步骤 9 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the two 4.3mm screws attaching the ribbons to the front case.
  10. Sony Alpha A350 Motherboard Replacement: 步骤 10 中的图像 1,1
    • After taking off the eye cup, remove two screws using a Phillips #00 screwdriver.
  11. Sony Alpha A350 Motherboard Replacement: 步骤 11 中的图像 1,2 Sony Alpha A350 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Gently pry the rear case off of the body of the camera using your hands or a spudger.
  12. Sony Alpha A350 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,2 Sony Alpha A350 Motherboard Replacement, Motherboard: 步骤 12 中的图像 2,2
    • After opening the case up and exposing the motherboard, remove five 3.6 mm screws with a Phillips #00 screwdriver from the board.
  13. Sony Alpha A350 Motherboard Replacement: 步骤 13 中的图像 1,3 Sony Alpha A350 Motherboard Replacement: 步骤 13 中的图像 2,3 Sony Alpha A350 Motherboard Replacement: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove all ribbon cables that are connected to the motherboard with a pair of tweezers or spudger by pulling them gently towards you.
  14. Sony Alpha A350 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Some of the ribbon cables are held in with minature clips. These cables can be identified by the side hinge that can be released with a pointed end.
  15. Sony Alpha A350 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Carefully pull up upward on the red and black wire ports with a pair of tweezers to remove the connections from the motherboard.
    • There are four total wire ports. two that you pull upward and two that you towards yourself.
  16. Sony Alpha A350 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Gently remove the motherboard now that all connections to the camera are removed.
    • If the motherboard does not lift out easily, look for screws or ribbons that were left still connected to the board.
结论
另外一个人完成了本指南。
Danielle Trivett
于11/04/19注册
337 声望
创作了3篇指南
团队
IUPUI, Team S1-G6, Henning Fall 2019 IUPUI, Team S1-G6, Henning Fall 2019 的会员
IUPUI-HENNING-F19S1G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 1,752
