简介
If your Cable Port Door is not functioning properly you may need to replace it.
你所需要的
Open the cable port door.
Identify and unscrew the two Phillips #000 screws.
Use the heavy duty spudger to lift up the port door compartment.
Remove the port door from the plastic body.
即将完成!
结论
另外一个人完成了本指南。
