跳转到主内容
Sony Alpha A3000 Motherboard Replacement
你所需要的
  1. Sony Alpha A3000 Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,3 Sony Alpha A3000 Motherboard Replacement, Rear Case: 步骤 1 中的图像 2,3 Sony Alpha A3000 Motherboard Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 Motherboard Replacement: 步骤 2 中的图像 1,2 Sony Alpha A3000 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 Motherboard Replacement: 步骤 3 中的图像 1,2 Sony Alpha A3000 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Sony Alpha A3000 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
    • Detach the facing for the memory dock.
  5. Sony Alpha A3000 Motherboard Replacement: 步骤 5 中的图像 1,2 Sony Alpha A3000 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the eight screws securing the mount for the flash device.
  6. Sony Alpha A3000 Motherboard Replacement: 步骤 6 中的图像 1,2 Sony Alpha A3000 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the three remaining screws holding in the protective metal casing.
  7. Sony Alpha A3000 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the metal casing.
  8. Sony Alpha A3000 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove three screws holding down the motherboard .
  9. Sony Alpha A3000 Motherboard Replacement: 步骤 9 中的图像 1,2 Sony Alpha A3000 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Detach the nine serial cables connecting it to the camera body.
  10. Sony Alpha A3000 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Finally remove the motherboard from the casing.
结论
6等其他人完成本指南。
团队
USF Tampa, Team 4-4, Meier Fall 2015 USF Tampa, Team 4-4, Meier Fall 2015 的会员
USFT-MEIER-F15S4G4
4 名成员
创作了10篇指南
一条评论
Then loose the plug all the motherboard?
kongre172 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 2,422
