跳转到主内容
Sony Alpha A3000 Built-in flash Replacement
你所需要的
  1. Sony Alpha A3000 Built-in flash Replacement, Rear Case: 步骤 1 中的图像 1,3 Sony Alpha A3000 Built-in flash Replacement, Rear Case: 步骤 1 中的图像 2,3 Sony Alpha A3000 Built-in flash Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 Built-in flash Replacement: 步骤 2 中的图像 1,2 Sony Alpha A3000 Built-in flash Replacement: 步骤 2 中的图像 2,2
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 Built-in flash Replacement: 步骤 3 中的图像 1,2 Sony Alpha A3000 Built-in flash Replacement: 步骤 3 中的图像 2,2
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 Built-in flash Replacement, Built-in flash: 步骤 4 中的图像 1,1
    • Remove the single screw from the bottom of the flash device.
  5. Sony Alpha A3000 Built-in flash Replacement: 步骤 5 中的图像 1,1
    • Remove the flash cover by gently pulling it in an outward direction.
  6. Sony Alpha A3000 Built-in flash Replacement: 步骤 6 中的图像 1,1
    • Use a soldering tool to remove the three wires connecting the flash to the camera.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 4-4, Meier Fall 2015 USF Tampa, Team 4-4, Meier Fall 2015 的会员
USFT-MEIER-F15S4G4
4 名成员
创作了10篇指南
3条评论
Thx, saved me from draing costs for cleaning my viewfinder from watercolor paint. also hotshoe adapter disassembly was easier than other parts. be careful, if you want to do it!
Michael Smith - 回复
My LCD and viewfinder are not working anymore. I think is the flex that broke up... or the socket where is connected... And there is no replacement pieces in my country.......... As well as it is not a cheap camera for us........ I want to kill myself.........................
l2weenlive - 回复
Any procedure for SONY a6300 built-in flash replacement?
Vivek Dhar - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,923
