跳转到主内容
Sony Alpha A3000 Battery Replacement
  1. Sony Alpha A3000 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • The battery compartment is located on the bottom of the camera as shown. To access the battery slide the compartment switch from LOCK to OPEN.
    • Before operating on device, ensure that the camera is powered off and the surface of operation is clean and free of dirt or other obstructions.
  2. Sony Alpha A3000 Battery Replacement: 步骤 2 中的图像 1,1
    • Push back the blue tab releasing the battery which should spring forth on its own.
  3. Sony Alpha A3000 Battery Replacement: 步骤 3 中的图像 1,1
    • To insert replacement, depress the blue tab again inserting the battery as shown until the blue tab springs back into place. Ensure battery is secure, close the battery compartment and return the latch to the LOCK position.
    • The replacement battery must meet specifications declared by Sony.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 4-4, Meier Fall 2015 USF Tampa, Team 4-4, Meier Fall 2015 的会员
USFT-MEIER-F15S4G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 2,183
