跳转到主内容
Sony Alpha 5100 Front Plate Replacement
  1. Sony Alpha 5100 Front Plate Replacement, Battery: 步骤 1 中的图像 1,2 Sony Alpha 5100 Front Plate Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the power switch on the top of the camera to "off."
    • Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
  2. Sony Alpha 5100 Front Plate Replacement: 步骤 2 中的图像 1,1
    • Push the blue spring-loaded lever to release the battery.
    • Remove the battery from the camera.
  3. Sony Alpha 5100 Front Plate Replacement, Front Plate: 步骤 3 中的图像 1,3 Sony Alpha 5100 Front Plate Replacement, Front Plate: 步骤 3 中的图像 2,3 Sony Alpha 5100 Front Plate Replacement, Front Plate: 步骤 3 中的图像 3,3
    • Remove one 2mm Phillips #00 screw from the flash plate cover.
    • Use the spudger to pop the plate off.
    • Remove two 2mm Phillips #00 screws on the side of the camera.
  4. Sony Alpha 5100 Front Plate Replacement: 步骤 4 中的图像 1,2 Sony Alpha 5100 Front Plate Replacement: 步骤 4 中的图像 2,2
    • Pop the memory card door open by gently lifting the door up.
    • Remove two 2mm Phillips #00 screws from the side of the camera.
    • Remove three 2mm Phillips #00 screws on the bottom of the camera.
  5. Sony Alpha 5100 Front Plate Replacement: 步骤 5 中的图像 1,2 Sony Alpha 5100 Front Plate Replacement: 步骤 5 中的图像 2,2
    • Use the opening tool to gently pop the front plate apart from the body.
结论
Kevin Raggiani
于10/30/19注册
444 声望
创作了3篇指南
团队
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 UMass Dartmouth, Team S4-G6, Saloman Fall 2019 的会员
UMASSD-SALOMAN-F19S4G6
3 名成员
创作了8篇指南
一条评论
Hi, i need to access the shutter-on/off switch on my a5100. Which parts and screws do i need to take apart.?
Thank you,
Fabian,
Fabian - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 39
总计 1,272
