跳转到主内容
Sony Action Cam Mini HDR-AZ1 Gasket Replacement
你所需要的
  1. Sony Action Cam Mini HDR-AZ1 Gasket Replacement, Gasket Seal: 步骤 1 中的图像 1,2 Sony Action Cam Mini HDR-AZ1 Gasket Replacement, Gasket Seal: 步骤 1 中的图像 2,2
    • To open the case, slide the tab located on the underside of the case to the “unlock” position.
    • Press in the tabs, that are on the sides of the unlock tab, and pull down. This should cause the lid to open.
    • Remove the lid.
  2. Sony Action Cam Mini HDR-AZ1 Gasket Replacement: 步骤 2 中的图像 1,1
    • Using the plastic opening tool, wedge it between the O-Ring and the groove.
    • Move the tool around the ring, prying the gasket from the groove, until it is able to be grabbed.
  3. Sony Action Cam Mini HDR-AZ1 Gasket Replacement: 步骤 3 中的图像 1,1
    • Remove the O-Ring from the lid of the case.
结论
To place a new gasket in, follow these steps in reverse order, making sure the gasket is fully pushed back in around its entire perimeter.
Mathieu LaFond
于10/27/15注册
425 声望
创作了4篇指南
团队
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G7
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 624
