跳转到主内容
Sony Action Cam Mini HDR-AZ1 Battery Replacement
  1. Sony Action Cam Mini HDR-AZ1 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Sony Action Cam Mini HDR-AZ1 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Sony Action Cam Mini HDR-AZ1 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • To access the battery, first make sure the camera is out of the case.
    • Push down on the door lock, located on the rear of the action cam.
    • The door is unlocked if the little yellow square is showing.
    • Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
  2. Sony Action Cam Mini HDR-AZ1 Battery Replacement: 步骤 2 中的图像 1,3 Sony Action Cam Mini HDR-AZ1 Battery Replacement: 步骤 2 中的图像 2,3 Sony Action Cam Mini HDR-AZ1 Battery Replacement: 步骤 2 中的图像 3,3
    • Open the side panel outward to reveal the battery.
    • Be sure not to break the small piece of plastic securing the door to the camera.
    • Use the pull tab to pop the battery out of place.
结论
另外一个人完成了本指南。
Brody Bridges
于10/29/15注册
101 声望
撰写一个指南
团队
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G7
3 名成员
创作了10篇指南
一条评论
Comment changer la battrie du moniteur d'affichage ?
Claude Bouthé - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,113
