跳转到主内容
Sony Action Cam Mini HDR-AZ1 Battery Door Replacement
你所需要的
  1. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: 步骤 1 中的图像 1,3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: 步骤 1 中的图像 2,3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: 步骤 1 中的图像 3,3
    • To access the battery, first make sure the camera is out of the case.
    • Push down on the door lock, located on the rear of the action cam.
    • The door is unlocked if the little yellow square is showing.
    • Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
  2. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 步骤 2 中的图像 1,3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 步骤 2 中的图像 2,3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 步骤 2 中的图像 3,3
    • Open the side panel outward to reveal the battery.
    • Be sure not to break the small piece of plastic securing the door to the camera.
    • Use the pull tab to pop the battery out of place.
  3. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: 步骤 3 中的图像 1,2 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: 步骤 3 中的图像 2,2
    • Remove the circled 4 millimeter black screw adjacent to where the door is attached.
  4. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 步骤 4 中的图像 1,2 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 步骤 4 中的图像 2,2
    • Grab the small black bracket holding the ribbon on which the door is attached and pull it out.
  5. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 步骤 5 中的图像 1,1
    • Pull the door straight back so the attaching ribbon is pulled taught and the door will come right off.
结论
Mathieu LaFond
于10/27/15注册
425 声望
创作了4篇指南
团队
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G7
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 820
