跳转到主内容
Sony Action Cam HDR-AS15 Speaker Replacement
你所需要的
  1. Sony Action Cam HDR-AS15 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • To access the battery, gently pry open the rear cover of the action cam.
  2. Sony Action Cam HDR-AS15 Speaker Replacement: 步骤 2 中的图像 1,2 Sony Action Cam HDR-AS15 Speaker Replacement: 步骤 2 中的图像 2,2
    • Using a pair of tweezers, firmly grip the protrusion where the PULL signifies and remove the tray and battery.
  3. Sony Action Cam HDR-AS15 Speaker Replacement, Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 3 中的图像 1,3 Sony Action Cam HDR-AS15 Speaker Replacement, Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 3 中的图像 2,3 Sony Action Cam HDR-AS15 Speaker Replacement, Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 3 中的图像 3,3
    • Open the bottom tab with your finger or a plastic opening tool.
    • Pull the tab out, not up, to remove it completely.
    • Remove the two screws from the device.
    • Use your fingers to remove the plastic plate.
  4. Sony Action Cam HDR-AS15 Speaker Replacement: 步骤 4 中的图像 1,1
    • Separate the outer casing from the electronics by pushing on one of the ports toward the back end of the case. The electronics should slide right out.
  5. Sony Action Cam HDR-AS15 Speaker Replacement: 步骤 5 中的图像 1,2 Sony Action Cam HDR-AS15 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the two 6.4 mm screws on the LCD side of the device using a Phillips #00 screwdriver.
    • Flip the LCD display downward to reveal the circuit board.
  6. Sony Action Cam HDR-AS15 Speaker Replacement, Removing the tape: 步骤 6 中的图像 1,2 Sony Action Cam HDR-AS15 Speaker Replacement, Removing the tape: 步骤 6 中的图像 2,2
    • Remove the tape holding the speaker down.
  7. Sony Action Cam HDR-AS15 Speaker Replacement, Removing the speaker: 步骤 7 中的图像 1,1
    • Desolder the speaker wires from the circuit board
    • To desolder, turn the soldering iron on and let it heat up
    • Touch the tip of the soldering iron to one of the solder joints until it melts. This will happen very quickly.
    • Pull the wire out of the solder and remove the soldering iron.
    • Repeat the last 3 steps for the second wire
结论
另外一个人完成了本指南。
Justin Calean
于01/09/15注册
421 声望
创作了4篇指南
团队
USF Tampa, Team 1-2, Sullivan Winter 2015 USF Tampa, Team 1-2, Sullivan Winter 2015 的会员
USFT-SULLIVAN-W15S1G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 440
