跳转到主内容
Sony Action Cam HDR-AS15 O-Ring Replacement
你所需要的
  1. Sony Action Cam HDR-AS15 O-Ring Replacement, Open the Waterproof Case: 步骤 1 中的图像 1,1
    • To open the case, push the yellow "Open" tab located at the bottom of the case.
    • Pull out on the yellow tabs as indicated by the circles in the photo to unlock the lid. This may be a little tricky!
    • Then, remove the lid.
  2. Sony Action Cam HDR-AS15 O-Ring Replacement, Pry the O-ring from the Groove: 步骤 2 中的图像 1,1
    • Take the plastic opening tool and wedge it between the O-ring and the groove.
    • Then, pry the O-ring until it is out of the groove.
  3. Sony Action Cam HDR-AS15 O-Ring Replacement, Remove the O-ring: 步骤 3 中的图像 1,1
    • Now that the O-ring is out of the groove, remove the O-ring from the lid.
结论
Justin Calean
于01/09/15注册
421 声望
创作了4篇指南
团队
USF Tampa, Team 1-2, Sullivan Winter 2015 USF Tampa, Team 1-2, Sullivan Winter 2015 的会员
USFT-SULLIVAN-W15S1G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 11
总计 876
