跳转到主内容
Sony AZ1VR LCD Side Display Replacement
你所需要的
  1. Sony AZ1VR LCD Side Display Replacement, LCD Side Display: 步骤 1 中的图像 1,3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: 步骤 1 中的图像 2,3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: 步骤 1 中的图像 3,3
    • Remove the two screws on the bottom of the camera.
    • Remove the screw inside the battery door.
    • Once these are removed, slide the door out, and the small piece of plastic with the door.
  2. Sony AZ1VR LCD Side Display Replacement: 步骤 2 中的图像 1,3 Sony AZ1VR LCD Side Display Replacement: 步骤 2 中的图像 2,3 Sony AZ1VR LCD Side Display Replacement: 步骤 2 中的图像 3,3
    • Grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
    • You'll see a screw on the top of the device, towards the front, remove this screw.
    • Pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
  3. Sony AZ1VR LCD Side Display Replacement: 步骤 3 中的图像 1,3 Sony AZ1VR LCD Side Display Replacement: 步骤 3 中的图像 2,3 Sony AZ1VR LCD Side Display Replacement: 步骤 3 中的图像 3,3
    • Remove the screws connected to the silver metal plate.
    • Remove the plate by pulling the back up and pushing it towards the front.
    • Remove the screw directly above the LCD display.
    • Pull the plastic up gently, it will be connected by cables on the bottom.
    • Disconnect the cable going to the LCD display.
结论
Michael Martin
于03/08/17注册
401 声望
创作了4篇指南
团队
UMass Dartmouth, Team S3-G5, Botvin Spring 2017 UMass Dartmouth, Team S3-G5, Botvin Spring 2017 的会员
UMASSD-BOTVIN-S17S3G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 138
