跳转到主内容
Sony α6500 Viewfinder Glass Replacement
你所需要的
  1. Sony α6500 Viewfinder Glass Replacement, Battery: 步骤 1 中的图像 1,1
    • Verify the camera is powered off by setting the switch to OFF.
  2. Sony α6500 Viewfinder Glass Replacement: 步骤 2 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 2 中的图像 2,2
    • Flip the camera upside down.
    • Slide the battery compartment lock to OPEN to unlock it.
  3. Sony α6500 Viewfinder Glass Replacement: 步骤 3 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 3 中的图像 2,2
    • Push the blue lever aside to release the battery.
  4. Sony α6500 Viewfinder Glass Replacement: 步骤 4 中的图像 1,1
    • Remove the released battery from the compartment.
  5. Sony α6500 Viewfinder Glass Replacement, Top Assembly: 步骤 5 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement, Top Assembly: 步骤 5 中的图像 2,2
    • To access the back of the camera remove the screws attaching the LCD screen hinge to the camera body.
    • Remove four 3 mm JIS 000 screws.
    • Remove one 3 mm JIS 00 screw.
    • After dismounting the screen hinge be careful to avoid tearing the black wire ribbon connecting the screen to the camera body.
  6. Sony α6500 Viewfinder Glass Replacement: 步骤 6 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 6 中的图像 2,2
    • Grasp the viewfinder eyecup; slide it up and off the viewfinder.
  7. Sony α6500 Viewfinder Glass Replacement: 步骤 7 中的图像 1,3 Sony α6500 Viewfinder Glass Replacement: 步骤 7 中的图像 2,3 Sony α6500 Viewfinder Glass Replacement: 步骤 7 中的图像 3,3
    • Press the flash popup button on the back of the camera.
    • Remove one 5 mm JIS 00 screw from inside the flash compartment.
    • Remove one 4 mm JIS 00 screw.
  8. Sony α6500 Viewfinder Glass Replacement: 步骤 8 中的图像 1,3 Sony α6500 Viewfinder Glass Replacement: 步骤 8 中的图像 2,3 Sony α6500 Viewfinder Glass Replacement: 步骤 8 中的图像 3,3
    • To remove the top of the camera you must remove the back first.
    • Remove the 2.5 mm JIS 00 screw from the side of the camera near the viewfinder.
    • Use the opening tool to pry off the small cover.
    • Remove two 2.5 mm JIS 00 screws from underneath the cover.
    • Remove a 5 mm JIS 00 screw from underneath the cover.
  9. Sony α6500 Viewfinder Glass Replacement: 步骤 9 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 9 中的图像 2,2
    • Remove three 2.5 mm JIS 0 screws from the back face of the camera.
    • Remove one 4 mm JIS 00 screw from the underside of the lip that overhangs the back of the camera.
  10. Sony α6500 Viewfinder Glass Replacement: 步骤 10 中的图像 1,1
    • Remove four 4 mm JIS 0 screws from the bottom of the camera.
  11. Sony α6500 Viewfinder Glass Replacement: 步骤 11 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 11 中的图像 2,2
    • Flip the battery lock switch to open and open the battery compartment.
    • Remove three 2.5 mm JIS 00 screws from the top of the battery compartment.
    • You may need a longer or thinner screwdriver to reach the screws in the battery compartment.
  12. Sony α6500 Viewfinder Glass Replacement: 步骤 12 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 12 中的图像 2,2
    • Use the plastic opening tool to begin prying off the back of the camera from the side.
    • Continue to loosen the back until you can open it from the bottom.
  13. Sony α6500 Viewfinder Glass Replacement: 步骤 13 中的图像 1,3 Sony α6500 Viewfinder Glass Replacement: 步骤 13 中的图像 2,3 Sony α6500 Viewfinder Glass Replacement: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Open the back of the camera.
    • Use tweezers to remove two ribbon connectors from underneath the back. One connects to the LCD display and the other connects to the right side behind the battery compartment.
    • Ribbon connectors can tear easily. Grasp the plastic ends (not the ribbon) when removing.
  14. Sony α6500 Viewfinder Glass Replacement: 步骤 14 中的图像 1,3 Sony α6500 Viewfinder Glass Replacement: 步骤 14 中的图像 2,3 Sony α6500 Viewfinder Glass Replacement: 步骤 14 中的图像 3,3
    • Use the plastic opening tool to peel down the rubber grip around the handle at least 1 cm.
    • The adhesive holding the rubber grip down should be strong enough to reattach when you are done. If not, you may need an adhesive to reglue it.
    • Remove one 3 mm JIS 000 screw from underneath the rubber grip on the right side.
    • Remove one 4 mm JIS 000 screw from the left side.
  15. Sony α6500 Viewfinder Glass Replacement: 步骤 15 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 15 中的图像 2,2
    • The last screws holding the top on can be accessed once the back of the camera is removed.
    • Remove one 2.5 mm JIS 00 screw from the top next to the flash mount.
  16. Sony α6500 Viewfinder Glass Replacement: 步骤 16 中的图像 1,3 Sony α6500 Viewfinder Glass Replacement: 步骤 16 中的图像 2,3 Sony α6500 Viewfinder Glass Replacement: 步骤 16 中的图像 3,3
    • Insert a long, thin JIS 00 screwdriver through the two holes and into the battery compartment; remove the two 5mm JIS 00 screws inside it.
  17. Sony α6500 Viewfinder Glass Replacement: 步骤 17 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 17 中的图像 2,2
    • Use the long, thin, screwdriver to remove one 5 mm JIS 00 screw inside the camera accessible below the dials from the back.
  18. Sony α6500 Viewfinder Glass Replacement: 步骤 18 中的图像 1,3 Sony α6500 Viewfinder Glass Replacement: 步骤 18 中的图像 2,3 Sony α6500 Viewfinder Glass Replacement: 步骤 18 中的图像 3,3
    • Use the plastic opening tool to gently lift up the shutter button assembly.
    • Grasp the front grip from the top and bottom and pull it off. It should come off easily with the shutter button out of the way.
    • The shutter button will still be attached by one ribbon cable once the front grip is removed.
  19. Sony α6500 Viewfinder Glass Replacement: 步骤 19 中的图像 1,3 Sony α6500 Viewfinder Glass Replacement: 步骤 19 中的图像 2,3 Sony α6500 Viewfinder Glass Replacement: 步骤 19 中的图像 3,3
    • Remove one 2.5 mm JIS 00 screw from where the shutter button assembly used to be.
    • Remove one 3 mm JIS 00 screw from the side of the camera.
  20. Sony α6500 Viewfinder Glass Replacement: 步骤 20 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 20 中的图像 2,2
    • Carefully unplug the two ribbon connectors attaching the top assembly to the rest of the camera.
  21. Sony α6500 Viewfinder Glass Replacement, Viewfinder Glass: 步骤 21 中的图像 1,3 Sony α6500 Viewfinder Glass Replacement, Viewfinder Glass: 步骤 21 中的图像 2,3 Sony α6500 Viewfinder Glass Replacement, Viewfinder Glass: 步骤 21 中的图像 3,3
    • From the top of the camera remove one 4mm JIS 00 screw.
    • Remove one 5mm JIS 00 screw and the plastic bushing around it.
    • Remove the viewfinder's protective cover.
  22. Sony α6500 Viewfinder Glass Replacement: 步骤 22 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 22 中的图像 2,2
    • Use the spudger to pry the light sensor off the side of the viewfinder.
    • When prying off the sensor, bend it out from the bottom.
    • Remove one 2.5mm JIS 000 screw on the side of the viewfinder to release it.
  23. Sony α6500 Viewfinder Glass Replacement: 步骤 23 中的图像 1,2 Sony α6500 Viewfinder Glass Replacement: 步骤 23 中的图像 2,2
    • Lift the viewfinder out and flip up the tab to release the wire ribbon where it is connected to the motherboard.
结论
另外一个人完成了本指南。
Jackson Furie
于10/10/19注册
807 声望
创作了5篇指南
团队
Cal Poly, Team S11-G5, Regan Fall 2019 Cal Poly, Team S11-G5, Regan Fall 2019 的会员
CPSU-REGAN-F19S11G5
5 名成员
创作了14篇指南
2条评论
This really helped me. I changed my VF unit with no problem. And btw, it is not necessary to unplug LCD cable. I havent done it, as i thought it would be really tricky to put it back in and it was just alright. Just tape the display to back panel while manipulating it so you dont twist the cables.
Adam Barus - 回复
Thanks for this
Where can I get the viewfinder glass though
Kojo Erskine Coffie - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 62
总计 1,628
