跳转到主内容
Sony α6000 Back Case Replacement
你所需要的
  1. Sony α6000 Back Case Replacement, Battery: 步骤 1 中的图像 1,2 Sony α6000 Back Case Replacement, Battery: 步骤 1 中的图像 2,2
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Back Case Replacement: 步骤 2 中的图像 1,2 Sony α6000 Back Case Replacement: 步骤 2 中的图像 2,2
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Back Case Replacement: 步骤 3 中的图像 1,2 Sony α6000 Back Case Replacement: 步骤 3 中的图像 2,2
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Back Case Replacement: 步骤 4 中的图像 1,2 Sony α6000 Back Case Replacement: 步骤 4 中的图像 2,2
    • Remove the battery.
  5. Sony α6000 Back Case Replacement, Back Case: 步骤 5 中的图像 1,1
    • Position the camera with the bottom facing upwards and the lens facing away from you.
  6. Sony α6000 Back Case Replacement: 步骤 6 中的图像 1,1
    • Once the battery is removed, use a Phillips #00 screwdriver to remove the three screws at the bottom of the battery compartment.
  7. Sony α6000 Back Case Replacement: 步骤 7 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the screws located next to the camera strap.
    • There may be screws on either side by the camera strap mounts. If removing the screw on the left side doesn't sufficiently loosen the case, be sure to check for a screw on the other side before resorting to excessive force.
  8. Sony α6000 Back Case Replacement: 步骤 8 中的图像 1,2 Sony α6000 Back Case Replacement: 步骤 8 中的图像 2,2
    • Position the camera with the battery housing facing upwards.
    • Remove the two screws on the bottom of the camera using the Phillips #00 screwdriver.
  9. Sony α6000 Back Case Replacement: 步骤 9 中的图像 1,1
    • Position the camera with the flash assembly facing upwards.
    • Remove the screw located underneath with a Phillips #00 screwdriver.
  10. Sony α6000 Back Case Replacement: 步骤 10 中的图像 1,2 Sony α6000 Back Case Replacement: 步骤 10 中的图像 2,2
    • Pull back the LCD screen.
    • Remove the three screws directly underneath using the Phillips #00 screwdriver.
  11. Sony α6000 Back Case Replacement: 步骤 11 中的图像 1,1
    • Gently pop off the top case of the camera using your fingers or a plastic opening tool.
    • If using a plastic opening tool, ensure that the pressure is being applied to the plastic rather than the metal.
  12. Sony α6000 Back Case Replacement: 步骤 12 中的图像 1,2 Sony α6000 Back Case Replacement: 步骤 12 中的图像 2,2
    • Position the camera with the LCD screen facing upwards.
    • Gently remove the back case guiding it around the LCD screen.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 36
总计 1,544
