跳转到主内容
Sonos Playbase Ethernet Port Replacement
你所需要的
  1. Sonos Playbase Ethernet Port Replacement, Bottom Panel: 步骤 1 中的图像 1,3 Sonos Playbase Ethernet Port Replacement, Bottom Panel: 步骤 1 中的图像 2,3 Sonos Playbase Ethernet Port Replacement, Bottom Panel: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $74.95
    购买
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase Ethernet Port Replacement: 步骤 2 中的图像 1,2 Sonos Playbase Ethernet Port Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $74.95
    购买
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase Ethernet Port Replacement: 步骤 3 中的图像 1,2 Sonos Playbase Ethernet Port Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $74.95
    购买
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase Ethernet Port Replacement, Ethernet Port: 步骤 4 中的图像 1,2 Sonos Playbase Ethernet Port Replacement, Ethernet Port: 步骤 4 中的图像 2,2
    • Unplug the Ethernet Port from the main circuit board by pinching the white clip and pulling upward.
  5. Sonos Playbase Ethernet Port Replacement: 步骤 5 中的图像 1,2 Sonos Playbase Ethernet Port Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $74.95
    购买
    • Remove the two 18 mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
  6. Sonos Playbase Ethernet Port Replacement: 步骤 6 中的图像 1,2 Sonos Playbase Ethernet Port Replacement: 步骤 6 中的图像 2,2
    • Remove the Ethernet Port from the housing by pinching from both sides and pulling it out.
结论
James Andrews
于10/08/18注册
421 声望
创作了4篇指南
团队
Cal Poly, Team S17-G2, White Fall 2018 Cal Poly, Team S17-G2, White Fall 2018 的会员
CPSU-WHITE-F18S17G2
4 名成员
创作了8篇指南
一条评论
I actually have a broken ethernet port on a playbase. Do you have any idea where I can buy a replacement port?
Thanks,
D
david paler - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 13
总计 1,436
