跳转到主内容
Sonos Play 5 Power Board Replacement
你所需要的
  1. Sonos Play 5 Power Board Replacement, Front Panel Assembly: 步骤 1 中的图像 1,1
    • Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
    • Flip the speaker upside down.
    • There may be a rubber foot covering the bottom screws (not included in picture). Remove this by pulling up from one of the corners using a spudger.
  2. Sonos Play 5 Power Board Replacement: 步骤 2 中的图像 1,2 Sonos Play 5 Power Board Replacement: 步骤 2 中的图像 2,2
    • Remove eight 10mm Phillips #2 screws
    • Remove the bottom panel by pulling upwards.
    • Be very gentle with the ends of the three antennas. They are very fragile.
  3. Sonos Play 5 Power Board Replacement: 步骤 3 中的图像 1,3 Sonos Play 5 Power Board Replacement: 步骤 3 中的图像 2,3 Sonos Play 5 Power Board Replacement: 步骤 3 中的图像 3,3
    • Flip the device so that the grille is facing up.
    • Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
    • Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
    • Gently pull up on the grille, removing it from the front panel.
  4. Sonos Play 5 Power Board Replacement: 步骤 4 中的图像 1,1
    • Remove the six 8mm Phillips #2 screws.
    • Remove the two 10mm Phillips #2 screws.
  5. Sonos Play 5 Power Board Replacement: 步骤 5 中的图像 1,2 Sonos Play 5 Power Board Replacement: 步骤 5 中的图像 2,2
    • Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
    • Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
    • Gently pull up on the face plate to ensure it has been detached from the enclosure.
    • When pulling on the face plate be cautious because it is still connected by wires on the back of the plate.
  6. Sonos Play 5 Power Board Replacement: 步骤 6 中的图像 1,3 Sonos Play 5 Power Board Replacement: 步骤 6 中的图像 2,3 Sonos Play 5 Power Board Replacement: 步骤 6 中的图像 3,3
    • Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
    • Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
    • The faceplate assembly is now fully detached from the rest of the speaker.
  7. Sonos Play 5 Power Board Replacement, Motherboard: 步骤 7 中的图像 1,3 Sonos Play 5 Power Board Replacement, Motherboard: 步骤 7 中的图像 2,3 Sonos Play 5 Power Board Replacement, Motherboard: 步骤 7 中的图像 3,3
    • Remove the ten pin connector.
  8. Sonos Play 5 Power Board Replacement: 步骤 8 中的图像 1,1
    • Flip the device over on its front side.
  9. Sonos Play 5 Power Board Replacement: 步骤 9 中的图像 1,1
    • Remove six 5mm Phillips #0 screws.
    • Remove two 7mm Phillips #2 screws.
  10. Sonos Play 5 Power Board Replacement: 步骤 10 中的图像 1,1
    • Flip the device on its back.
  11. Sonos Play 5 Power Board Replacement: 步骤 11 中的图像 1,3 Sonos Play 5 Power Board Replacement: 步骤 11 中的图像 2,3 Sonos Play 5 Power Board Replacement: 步骤 11 中的图像 3,3
    • Remove the grey and red antenna connectors by lifting them away from the board.
    • Pull cords away from the board.
  12. Sonos Play 5 Power Board Replacement: 步骤 12 中的图像 1,2 Sonos Play 5 Power Board Replacement: 步骤 12 中的图像 2,2
    • Remove the yellow antenna connector by lifting it away from the board.
    • Pull cord away from the board.
  13. Sonos Play 5 Power Board Replacement: 步骤 13 中的图像 1,3 Sonos Play 5 Power Board Replacement: 步骤 13 中的图像 2,3 Sonos Play 5 Power Board Replacement: 步骤 13 中的图像 3,3
    • Remove circuit board by lifting it straight away from the rear plate.
  14. Sonos Play 5 Power Board Replacement, Power Board: 步骤 14 中的图像 1,1
    • Lay the two connected boards so that the power board is facing upwards.
  15. Sonos Play 5 Power Board Replacement: 步骤 15 中的图像 1,2 Sonos Play 5 Power Board Replacement: 步骤 15 中的图像 2,2
    • Unscrew four Phillips #2 bolts.
    • These bolts will not come out, but will pull out of the nuts on the other side of the board.
  16. Sonos Play 5 Power Board Replacement: 步骤 16 中的图像 1,1
    • Flip boards so audio board is facing upwards, as is shown in picture.
  17. Sonos Play 5 Power Board Replacement: 步骤 17 中的图像 1,3 Sonos Play 5 Power Board Replacement: 步骤 17 中的图像 2,3 Sonos Play 5 Power Board Replacement: 步骤 17 中的图像 3,3
    • Lift control board up and away from power supply board.
  18. Sonos Play 5 Power Board Replacement: 步骤 18 中的图像 1,1
    • The larger of the two boards is the power supply board.
结论
15等其他人完成本指南。
团队
USF Tampa, Team S3-G6, Sullivan Spring 2017 USF Tampa, Team S3-G6, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S3G6
4 名成员
创作了16篇指南
9条评论
Great guide but where can you get replacement boards from, if at all?
Mark Molloy - 回复
Yes good question, where to get a replacement board SONOS P/N: 170-00236?
Model: JB Power Board
B. Buil - 回复
Does anyone know the specs on the five electrolytic capacitors that are arranged vertically (on the left side of the last image above)? I have a couple failing on one board, and I think that’s what is causing the amp to ‘click’ once it warms up.
T C - 回复
We replaced the parts listed in the description of this clip, and the unit came back to life: https://www.youtube.com/watch?v=2R8hKdGT...
The procedure is a bit unclear in the clip, suggest following the ifixit-procedure, or both.
Roger Bratseth - 回复
Thank you for your work here. Youtube video also useful.
I needed to purchase quality solder iron plus tips, solder wick, and review how to desolder capacitors. Taking out the bad fuse and the rectifier were relatively easy, but the capacitors were covered in silicone, then the old solder on its terminals proved very difficult to melt. In the end, even with temperature of tip at 340, little progress was made, so I disassembled capacitor in situ, and finally with more heat the remnant of it and the two terminals popped out. Again ,I saw this technique on YouTube.
So, having had a live chat with sonos who told me I had no warranty and it was unfixable, and that the new sonos5 is not compatible with my current Generation 1 system, I got the thing working, with next to no initial knowledge.
Cost
£90 in tools- solder iron, tips, quality electronic pliers
£10 in components from Farnell
And about 6 hours disassemble, doing the biz ( the learning curve of desoldering, removing caps, fuse, rectifier) then reassembling
Gordon Mckenna - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 185
总计 23,664
