跳转到主内容
Sonos Play 3 Tweeter Speaker Replacement
你所需要的
  1. Sonos Play 3 Tweeter Speaker Replacement, Speaker Grille: 步骤 1 中的图像 1,2 Sonos Play 3 Tweeter Speaker Replacement, Speaker Grille: 步骤 1 中的图像 2,2
    • Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
  2. Sonos Play 3 Tweeter Speaker Replacement: 步骤 2 中的图像 1,1
    • Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
    • There may be a kind of black sticky adhesive holding the screen clips to the rest of the body; however, it was previously removed on our model.
  3. Sonos Play 3 Tweeter Speaker Replacement, Front Speaker Panel: 步骤 3 中的图像 1,2 Sonos Play 3 Tweeter Speaker Replacement, Front Speaker Panel: 步骤 3 中的图像 2,2
    • Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box.
    • Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
    • Unscrew the single 3/4 inch Phillips #2 screw, which is the last thing holding the front panel to the casing.
  4. Sonos Play 3 Tweeter Speaker Replacement: 步骤 4 中的图像 1,3 Sonos Play 3 Tweeter Speaker Replacement: 步骤 4 中的图像 2,3 Sonos Play 3 Tweeter Speaker Replacement: 步骤 4 中的图像 3,3
    • Remove the front panel carefully.
    • Note that there are two layers to the panel that should stay in their original order.
  5. Sonos Play 3 Tweeter Speaker Replacement: 步骤 5 中的图像 1,2 Sonos Play 3 Tweeter Speaker Replacement: 步骤 5 中的图像 2,2
    • Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
  6. Sonos Play 3 Tweeter Speaker Replacement: 步骤 6 中的图像 1,2 Sonos Play 3 Tweeter Speaker Replacement: 步骤 6 中的图像 2,2
    • Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb.
  7. Sonos Play 3 Tweeter Speaker Replacement, Tweeter Speaker: 步骤 7 中的图像 1,3 Sonos Play 3 Tweeter Speaker Replacement, Tweeter Speaker: 步骤 7 中的图像 2,3 Sonos Play 3 Tweeter Speaker Replacement, Tweeter Speaker: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to disconnect the wire connectors from the tweeter speaker. The connectors may be very tight, but we promise they do come off.
  8. Sonos Play 3 Tweeter Speaker Replacement: 步骤 8 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the screws securing the speaker to the front panel.
  9. Sonos Play 3 Tweeter Speaker Replacement: 步骤 9 中的图像 1,2 Sonos Play 3 Tweeter Speaker Replacement: 步骤 9 中的图像 2,2
    • Carefully lift the tweeter speaker out the front of the panel.
结论
4等其他人完成本指南。
Christina Santini
于04/14/16注册
1,350 声望
创作了7篇指南
团队
Cal Poly, Team 25-6, Maness Spring 2016 Cal Poly, Team 25-6, Maness Spring 2016 的会员
CPSU-MANESS-S16S25G6
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 1,293
