跳转到主内容
Sonos Play 1 Motherboard Replacement
你所需要的
  1. Sonos Play 1 Motherboard Replacement, Exterior Screen: 步骤 1 中的图像 1,2 Sonos Play 1 Motherboard Replacement, Exterior Screen: 步骤 1 中的图像 2,2
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Sonos Play 1 Motherboard Replacement: 步骤 2 中的图像 1,2 Sonos Play 1 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Sonos Play 1 Motherboard Replacement: 步骤 3 中的图像 1,2 Sonos Play 1 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
  4. Sonos Play 1 Motherboard Replacement: 步骤 4 中的图像 1,2 Sonos Play 1 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Sonos Play 1 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the exterior screen by lifting it away from the bulk of the device.
  6. Sonos Play 1 Motherboard Replacement, Sonos Play 1 Top Cover Disassembly: 步骤 6 中的图像 1,1
    • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
  7. Sonos Play 1 Motherboard Replacement: 步骤 7 中的图像 1,3 Sonos Play 1 Motherboard Replacement: 步骤 7 中的图像 2,3 Sonos Play 1 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Using a plastic opening tool, pry open the top cap containing the power and volume button.
    • Vertically remove the top cap.
    • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
  8. Sonos Play 1 Motherboard Replacement: 步骤 8 中的图像 1,2 Sonos Play 1 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Using a plastic opening tool, pry open the circuit flap.
    • Once flap is loosened, use your hand to remove the circuit wire.
  9. Sonos Play 1 Motherboard Replacement, Disassembling Sonos Play 1 Rear Housing Cover: 步骤 9 中的图像 1,2 Sonos Play 1 Motherboard Replacement, Disassembling Sonos Play 1 Rear Housing Cover: 步骤 9 中的图像 2,2
    • Using a plastic opening tool, remove the grey tape from both sides of the device.
  10. Sonos Play 1 Motherboard Replacement: 步骤 10 中的图像 1,2 Sonos Play 1 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove the six 9 mm Torx #9 screws.
    • Using a plastic opening tool, detach the rear housing cover from the housing.
    • Try not to jerk the rear housing cover, as its wires are still connected to delicate electronics.
  11. Sonos Play 1 Motherboard Replacement: 步骤 11 中的图像 1,2 Sonos Play 1 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Using tweezers, grip the connector fixed to the motherboard's audio cable.
    • While pulling on the connector, detach the cable by pressing the connectors release.
  12. Sonos Play 1 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Using your fingers, grip the connector fixed to the motherboards power cable and detach it.
    • You will now be able to remove the rear housing cover.
  13. Sonos Play 1 Motherboard Replacement, Motherboard: 步骤 13 中的图像 1,2 Sonos Play 1 Motherboard Replacement, Motherboard: 步骤 13 中的图像 2,2
    • Remove the two 6 mm Torx #6 screws securing the communications board to the motherboard.
    • Using your fingers, detach and remove the communications board from the motherboard.
    • Be sure to keep the communications board parallel to the motherboard when removing as to prevent damage to the connector.
  14. Sonos Play 1 Motherboard Replacement: 步骤 14 中的图像 1,2 Sonos Play 1 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Remove the six 10 mm Torx #10 screws fastening the motherboard to the rear housing cover.
    • Using a plastic opening tool, remove the motherboard from the rear housing cover.
结论
7等其他人完成本指南。
Margarita
于09/03/15注册
180 声望
撰写一个指南
团队
USF Tampa, Team 8-4, Eyestone Fall 2015 USF Tampa, Team 8-4, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G4
4 名成员
创作了16篇指南
15条评论
Where do you get these replacement parts from - not directly from Sonos I understand.
iou_james - 回复
…by the way I am looking for a new motherboard for a Sonos Play1 unit.
iou_james - 回复
On a Play 1 r524 and r525 are blown. What are these.and how do I get replacements
houser_m.d - 回复
Same here. r524 and r525 look blown. Have you been able to identify their values? Did you find any further damage? Have you been able to repair it?
Oliver Krause -
The parts has 1R00 printed on them. 1R= 1 Ohm resistor. You can open an old electronic gadget or look at an old PC-motherboard and see if you find one there. It’s normally hard find surface mounted resistors in local stores…
Patrick Tollgren lazarov -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 38
过去 30 天: 188
总计 19,770
