跳转到主内容
Sonos Play 1 Exterior Screen Replacement
你所需要的
  1. Sonos Play 1 Exterior Screen Replacement, Exterior Screen: 步骤 1 中的图像 1,2 Sonos Play 1 Exterior Screen Replacement, Exterior Screen: 步骤 1 中的图像 2,2
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Sonos Play 1 Exterior Screen Replacement: 步骤 2 中的图像 1,2 Sonos Play 1 Exterior Screen Replacement: 步骤 2 中的图像 2,2
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Sonos Play 1 Exterior Screen Replacement: 步骤 3 中的图像 1,2 Sonos Play 1 Exterior Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
  4. Sonos Play 1 Exterior Screen Replacement: 步骤 4 中的图像 1,2 Sonos Play 1 Exterior Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Sonos Play 1 Exterior Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the exterior screen by lifting it away from the bulk of the device.
结论
12等其他人完成本指南。
团队
USF Tampa, Team 8-4, Eyestone Fall 2015 USF Tampa, Team 8-4, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G4
4 名成员
创作了16篇指南
6条评论
Where can you purchase a replacement screen please? I dented mine by accident.
Imran Behlim - 回复
I have the same question, where can i buy a replacement screen?
Bosyd - 回复
I have the same question,. Where can I buy a replacement screen?
Bosyd - 回复
worked great, with dents both peened out no metal stretch, can’t tell was ever damaged A+ info thanks. George
pogocat69 - 回复
where to buy the replacement screen?
joel-voetbal - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 98
总计 15,944
