Continue to work your way around the sides until the grille is freed.
Remove the four red circled Torx T20 screws securing the driver to the front panel.
The insulated terminal simply pulls off to disconnect.
The midwoofer may now be carefully removed from the supporting frame.
Raise the midwoofer out of the cabinet slightly to enable you to disconnect the terminals.
Again, the insulated terminal simply slides off, but the non insulated terminal's locking tab must be depressed.
Remove the four T20 screws securing the driver to the front panel
Lift the driver out of the cabinet.
The left noninsulated terminal again has a locking tab that must be depressed. (red arrow, photo two) The right terminal is simply pulled off.
另外一个人完成了本指南。
2指南评论
Hola sabes donde podría comprar los parlantes tengo un somos five y están las tres bocinas reventadas
Ricardo.tranamil.h@gmail.com
Hola nesecito comprar las bocinas de repuestos por favor
