跳转到主内容
Sonos Connect Top Motherboard Replacement
你所需要的
  1. Sonos Connect Top Motherboard Replacement, WIFI Card: 步骤 1 中的图像 1,3 Sonos Connect Top Motherboard Replacement, WIFI Card: 步骤 1 中的图像 2,3 Sonos Connect Top Motherboard Replacement, WIFI Card: 步骤 1 中的图像 3,3
    • Start by using a spudger or plastic opening tool to remove the bottom cover.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Once enough of the glue is removed, peel the cover off by hand,
  2. Sonos Connect Top Motherboard Replacement: 步骤 2 中的图像 1,3 Sonos Connect Top Motherboard Replacement: 步骤 2 中的图像 2,3 Sonos Connect Top Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the four 7.5mm length Philips head screws under the rubber cover.
  3. Sonos Connect Top Motherboard Replacement: 步骤 3 中的图像 1,3 Sonos Connect Top Motherboard Replacement: 步骤 3 中的图像 2,3 Sonos Connect Top Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use a nylon spudger to unsnap the bottom from the sides.
    • Pry until the remaining three points are unsnapped.
    • Once unsnapped, lift the cover.
  4. Sonos Connect Top Motherboard Replacement: 步骤 4 中的图像 1,2 Sonos Connect Top Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the connection for the front buttons to fully remove the cover.
  5. Sonos Connect Top Motherboard Replacement: 步骤 5 中的图像 1,2 Sonos Connect Top Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors.
    • Gently pull the wires at the connection point to disconnect them from the motherboard.
  6. Sonos Connect Top Motherboard Replacement: 步骤 6 中的图像 1,2 Sonos Connect Top Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the two pieces of glue holding the WIFI card in place.
  7. Sonos Connect Top Motherboard Replacement: 步骤 7 中的图像 1,3 Sonos Connect Top Motherboard Replacement: 步骤 7 中的图像 2,3 Sonos Connect Top Motherboard Replacement: 步骤 7 中的图像 3,3
    • Scrape the glued pad underneath the WIFI card to seperate the card from the board.
    • Push apart the two clips holding the WIFI card in the connection.
    • Pull the WIFI card out of the connection.
    • When putting the new WIFI card in, put the card in the connector first, then push downward until it clicks.
  8. Sonos Connect Top Motherboard Replacement, Top Motherboard: 步骤 8 中的图像 1,1
    • Remove the 7mm length Phillips screw holding the board in place.
  9. Sonos Connect Top Motherboard Replacement: 步骤 9 中的图像 1,2 Sonos Connect Top Motherboard Replacement: 步骤 9 中的图像 2,2
    • Flip the board over to access the Molex Cable.
  10. Sonos Connect Top Motherboard Replacement: 步骤 10 中的图像 1,1
    • Disconnect the Molex Cable from the top motherboard.
结论
2等其他人完成本指南。
Clark Snyder
于01/21/16注册
483 声望
创作了4篇指南
团队
IUPUI, Team 3-2, Baechle Spring 2016 IUPUI, Team 3-2, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S3G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 13
过去 30 天: 19
总计 1,881
