跳转到主内容
Sonos Bridge Ethernet Port Replacement
你所需要的
  1. Sonos Bridge Ethernet Port Replacement, Ethernet Port: 步骤 1 中的图像 1,1
    • The rubber bottom is glued on, meaning it can be easily pried off using the metal spudger.
    • You may have to pry from multiple locations.
  2. Sonos Bridge Ethernet Port Replacement: 步骤 2 中的图像 1,3 Sonos Bridge Ethernet Port Replacement: 步骤 2 中的图像 2,3 Sonos Bridge Ethernet Port Replacement: 步骤 2 中的图像 3,3
    • There is one screw in each corner of the base for a total of four screws.
    • Remove each screw using the Phillips 1 screwdriver.
    • The four screws are each 0.9 cm long.
    • The screws are small, so be careful to not lose them.
  3. Sonos Bridge Ethernet Port Replacement: 步骤 3 中的图像 1,2 Sonos Bridge Ethernet Port Replacement: 步骤 3 中的图像 2,2
    • Use the metal spudger to pry out the plastic bottom.
    • Alternatively, the casing can be lightly tapped on a table (base down) to drop the bottom out of the casing.
  4. Sonos Bridge Ethernet Port Replacement: 步骤 4 中的图像 1,2 Sonos Bridge Ethernet Port Replacement: 步骤 4 中的图像 2,2
    • Pry out the circuit board.
    • Place the metal spudger under the board on the side opposite the two ports.
    • The board can then be easily wiggled out of the casing.
    • This should NOT require significant force.
  5. Sonos Bridge Ethernet Port Replacement: 步骤 5 中的图像 1,3 Sonos Bridge Ethernet Port Replacement: 步骤 5 中的图像 2,3 Sonos Bridge Ethernet Port Replacement: 步骤 5 中的图像 3,3
    • Locate the Ethernet port on the circuit board, shown with the red box in the first image.
    • Locate the solders attached to the Ethernet port.
    • Use the soldering iron to undo the solders.
    • Carefully remove the Ethernet port by using the metal spudger and squeezing the black clips.
结论
Brian Strader
于11/07/17注册
201 声望
创作了2篇指南
团队
IUPUI, Team S3-G4, Harley Fall 2017 IUPUI, Team S3-G4, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G4
3 名成员
创作了2篇指南
一条评论
Hi could you tell me how to fix sonos zp100 bridge player internet port also where to get parts thanks
imranp7 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,708
