当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
First, you better download the "AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF REPAIR MANUAL". (The attatchment)
Remove Tripod mount (The one can be removed with only hands)
Remove tripod mount base by remove 4 screws.
short
long
Unscrew switch board and disconnect all 3 FPC's
Remove tripod ring, by removing 3 hidden screws. check the Repair Manual
Remove 11 screws and separate rear group. There is an empty hole.
这个步骤还没有翻译 帮忙翻译一下
More detail. The infinity end is glued using some better glue(dark material), while the close end is NOT.
The fix is
Mark or remember the position BEFORE removing 2 screws and contact brush! but relax, this part is not extremely precise.
Lift the PCB. Cleanup double sided tape. Glue the PCB back firmly against the inner edge.
7等其他人完成本指南。
附加文件
13条评论
Does this fault affect manual focus also ?
Thanks
It does. And might be worse, because MF sometimes goes faster than AF, then stuck deeper…
Terrance -
Will whis work even if my focus ring is stiff (but moves and “jumps”) AF works finw
