本指南有最近更改,您可查看未经巡查的最新版本。
简介
It is a very common issue the AF-S VR Zoom-Nikkor ED 70-200mm f2.8G IF focus ring stuck at close end. This will show Ifixers how to fix this.
你所需要的
The lens. Focusing mechanism traps in close-up end, worsens over time.
First, you better download the "AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF REPAIR MANUAL". (The attatchment)
Remove Tripod mount (The one can be removed with only hands)
Remove tripod mount base by remove 4 screws.
short
long
Unscrew switch board and disconnect all 3 FPC's
Remove tripod ring, by removing 3 hidden screws. check the Repair Manual
Remove 11 screws and separate rear group. There is an empty hole.
Take the front group. remove zoom rubber ring.
Peel the tape, and keep if you don't have a replacement.
Remove 2 screws.
Remove 3 screws and remove "4th Lens Group"
Unscrew 3 outer screws and remove Aperture Blade Unit
Remove 8 black screws and lift "Zoom Fixed Ring" and "MF Ring"
Here is the ISSUE. internal focus ring has contact with Distance readout PCB. The PCB is mounted by double sided tape. This is a design flaw. double sided tape drifts over time, and let the PCB slip out.
More detail. The infinity end is glued using some better glue(dark material), while the close end is NOT.
The fix is
Mark or remember the position BEFORE removing 2 screws and contact brush! but relax, this part is not extremely precise.
Lift the PCB. Cleanup double sided tape. Glue the PCB back firmly against the inner edge.
Be patient and Good Luck!!!
7等其他人完成本指南。
附加文件
13条评论
Does this fault affect manual focus also ?
Thanks
It does. And might be worse, because MF sometimes goes faster than AF, then stuck deeper…
Terrance -
Will whis work even if my focus ring is stiff (but moves and “jumps”) AF works finw
