简介
A rugged outdoor lifestyle may sometimes cause the cover, of your Solio Rocsta, to get dirty and/or damaged. In this guide, we will show you how to remove the top cover of the Solio Rocsta and replace it.
  1. Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Remove top cover.
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
    • Using the spudger, pry the solar panel off the cover.
结论
Denis Laesker
于2017年10月10日注册
107 信誉积分
撰写一个指南
团队
USF Tampa, Team S13-G13, Cagle Fall 2017 USF Tampa, Team S13-G13, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G13
4 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 23
