跳转到主内容
Solio Rocsta Internal Components Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Solio Rocsta Internal Components Replacement, Internal Components: 步骤 1 中的图像 1,1
    • Remove the three 7mm Torx T7 screws.
  2. Solio Rocsta Internal Components Replacement: 步骤 2 中的图像 1,3 Solio Rocsta Internal Components Replacement: 步骤 2 中的图像 2,3 Solio Rocsta Internal Components Replacement: 步骤 2 中的图像 3,3
    • Insert the flat end of the spudger between the top panel and the body.
    • Use the spudger as a lever to carefully pry apart the two panels.
    • As you pry, take care not to break the small orange clip holding the top to the body.
    • Lift the panel above and away to disconnect the panel from the body.
    • Be careful when lifting because you could break the wiring connecting the motherboard to the panel.
  3. Solio Rocsta Internal Components Replacement: 步骤 3 中的图像 1,2 Solio Rocsta Internal Components Replacement: 步骤 3 中的图像 2,2
    • Lift the panel off the body and set it next to the device.
    • Remember to use caution when lifting because you could break the wiring connecting the motherboard to the panel.
  4. Solio Rocsta Internal Components Replacement: 步骤 4 中的图像 1,1
    • Remove the two 6mm Torx T6 screws from the motherboard.
  5. Solio Rocsta Internal Components Replacement: 步骤 5 中的图像 1,2 Solio Rocsta Internal Components Replacement: 步骤 5 中的图像 2,2
    • Lift the end of the USB cord out of the body.
    • The cord fits over an orange peg.
  6. Solio Rocsta Internal Components Replacement: 步骤 6 中的图像 1,3 Solio Rocsta Internal Components Replacement: 步骤 6 中的图像 2,3 Solio Rocsta Internal Components Replacement: 步骤 6 中的图像 3,3
    • Lift up the battery with your fingers or with the flat end of the spudger.
    • Be prepared to use force because the battery is adhered to the body.
    • Do not try to remove the battery completely because the wiring connects to the motherboard.
  7. Solio Rocsta Internal Components Replacement: 步骤 7 中的图像 1,2 Solio Rocsta Internal Components Replacement: 步骤 7 中的图像 2,2
    • Remove the battery and the motherboard from the body.
结论
另外一个人完成了本指南。
Aimee Whiteside
于05/21/15注册
1 声望
撰写一个指南
团队
iFixit, Team 1-1, Goldberg SU 2015 iFixit, Team 1-1, Goldberg SU 2015 的会员
FIX-GOLDBERG-SU15S1G1
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 90
