跳转到主内容
Solio Rocsta Charging Indicator Button Replacement
你所需要的
  1. Solio Rocsta Charging Indicator Button Replacement, Solio Rocsta Top Cover Disassembly: 步骤 1 中的图像 1,2 Solio Rocsta Charging Indicator Button Replacement, Solio Rocsta Top Cover Disassembly: 步骤 1 中的图像 2,2
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta Charging Indicator Button Replacement: 步骤 2 中的图像 1,2 Solio Rocsta Charging Indicator Button Replacement: 步骤 2 中的图像 2,2
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
  3. Solio Rocsta Charging Indicator Button Replacement, Battery: 步骤 3 中的图像 1,1
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta Charging Indicator Button Replacement: 步骤 4 中的图像 1,1
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case and flip the circuit board.
  5. Solio Rocsta Charging Indicator Button Replacement: 步骤 5 中的图像 1,1
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
  6. Solio Rocsta Charging Indicator Button Replacement, Charging Indicator Button: 步骤 6 中的图像 1,1
    • Unscrew the 5.66 mm screws attaching the circuit board to the case.
  7. Solio Rocsta Charging Indicator Button Replacement: 步骤 7 中的图像 1,1
    • With a Soldering Iron desolder the charging indicator button connectors.
    • For more information on how to solder and desolder connections, please visit this guide.
  8. Solio Rocsta Charging Indicator Button Replacement: 步骤 8 中的图像 1,1
    • Gently pry the charging indicator button using one of the Precision Tweezers.
结论
David Vazquez
于10/10/17注册
577 声望
创作了5篇指南
团队
USF Tampa, Team S13-G13, Cagle Fall 2017 USF Tampa, Team S13-G13, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G13
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 60
