跳转到主内容
Solio CLASSIC2 Battery Replacement
你所需要的
  1. Solio CLASSIC2 Battery Replacement, Disconnecting the Battery: 步骤 1 中的图像 1,1
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
  2. Solio CLASSIC2 Battery Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  3. Solio CLASSIC2 Battery Replacement: 步骤 3 中的图像 1,3 Solio CLASSIC2 Battery Replacement: 步骤 3 中的图像 2,3 Solio CLASSIC2 Battery Replacement: 步骤 3 中的图像 3,3
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
  4. Solio CLASSIC2 Battery Replacement: 步骤 4 中的图像 1,2 Solio CLASSIC2 Battery Replacement: 步骤 4 中的图像 2,2
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
  5. Solio CLASSIC2 Battery Replacement: 步骤 5 中的图像 1,2 Solio CLASSIC2 Battery Replacement: 步骤 5 中的图像 2,2
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
  6. Solio CLASSIC2 Battery Replacement: 步骤 6 中的图像 1,2 Solio CLASSIC2 Battery Replacement: 步骤 6 中的图像 2,2
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
  7. Solio CLASSIC2 Battery Replacement, Circuit Board: 步骤 7 中的图像 1,1
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  8. Solio CLASSIC2 Battery Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
  9. Solio CLASSIC2 Battery Replacement, Battery: 步骤 9 中的图像 1,1
    • Remove the two 2mm screws from the battery case.
  10. Solio CLASSIC2 Battery Replacement: 步骤 10 中的图像 1,1
    • Gently pull up the battery case out of the tabs and pull the case out.
  11. Solio CLASSIC2 Battery Replacement: 步骤 11 中的图像 1,1
    • Gently lift up the battery.
结论
Johnny Tran
于10/21/13注册
311 声望
创作了3篇指南
团队
Cal Poly, Team 4-28, Amido Fall 2013 Cal Poly, Team 4-28, Amido Fall 2013 的会员
CPSU-AMIDO-F13S4G28
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 1,284
