跳转到主内容
SolarLog 300 Corrupt Firmware Fix
你所需要的
  1. SolarLog 300  Corrupt Firmware Fix, Open back panel: 步骤 1 中的图像 1,3 SolarLog 300  Corrupt Firmware Fix, Open back panel: 步骤 1 中的图像 2,3 SolarLog 300  Corrupt Firmware Fix, Open back panel: 步骤 1 中的图像 3,3
    • Remove all 4 screws with Torx T10 bit/driver (See Picture 2)
    • Then, remove the back panel to reveal the main PCB (See Picture 3)
  2. SolarLog 300  Corrupt Firmware Fix, Flip Main PCB: 步骤 2 中的图像 1,3 SolarLog 300  Corrupt Firmware Fix, Flip Main PCB: 步骤 2 中的图像 2,3 SolarLog 300  Corrupt Firmware Fix, Flip Main PCB: 步骤 2 中的图像 3,3
    • Slide the main PCB downwards, just a few millimeters for the top side to be lifted.(See Picture 1)
    • Lift the topside of the PCB but still keeping the bottom side stationary. (See Picture 2)The main reason therefore, is the display cable is conneted at the bottom side.(Indicated in yellow on the 3rd picture)
    • You will see the microSD card on the board.
  3. SolarLog 300  Corrupt Firmware Fix, Remove MicroSD card: 步骤 3 中的图像 1,1
    • Remove the MicroSD card by pressing inward to pop out.
  4. SolarLog 300  Corrupt Firmware Fix, Download New Firmware: 步骤 4 中的图像 1,1
    • By using a microSD card reader insert the new SD card into your computer.
    • Copy the downloaded firmware file to the new empty microSD card.
    • Rename the firmware file to: firmware_update.bin
    • Put the microSD card back into the unit and reverse the steps you took to take it apart.
    • Power up the unit and the screen will show FW indicating that the new firmware update has started.
    • Note all previous configuration and save data will be lost.
结论
Niel Lambrechts
于07/30/19注册
272 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 30
总计 2,240
