本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace the battery in your lantern so that it can hold a charge and be illuminated.
你所需要的
Flip lantern upside down and unscrew the 4 phillips head screws on the base and remove the base plate.
To disassemble the main body, grip the lantern so that the front half of the body with the power button on it is in your right hand and the back half with the hand crank is in your left.
Pinch the front half of the body on both sides with your thumb and index finger just below the first extruding rim of the front plate while simultaneously pulling the back half away. This may take some effort to do.
Locate the green rechargeable battery on the back plate. It is press fit into the housing near the bottom of the back half.
Trace the red and black wires from the battery to the white clip connecting them to the main power board. Pull out the white clip from the socket on the main board. This will sever the electrical connection between the battery and the rest of the lantern.
Now that the wires are removed, remove battery from housing on the back plate.
