跳转到主内容
Sol Republic Deck Play/Pause Button Replacement
你所需要的
  1. Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: 步骤 1 中的图像 1,3 Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: 步骤 1 中的图像 2,3 Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: 步骤 1 中的图像 3,3
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry the front face plate from the bottom half of the speaker by inserting the spudger edge into the the middle groove.
    • Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
  2. Sol Republic Deck Play/Pause Button Replacement: 步骤 2 中的图像 1,1
    • On the front face of the device, locate the green plastic Motorola (M) button that controls the playing and pausing of music.
  3. Sol Republic Deck Play/Pause Button Replacement: 步骤 3 中的图像 1,1
    • Using your finger, push the M button towards the inside of the device.
  4. Sol Republic Deck Play/Pause Button Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using the tweezers, grab the button as it comes through and pull it carefully off of the pegs.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 895
