跳转到主内容
Sol Republic Deck Bluetooth Button Replacement
你所需要的
  1. Sol Republic Deck Bluetooth Button Replacement, Bluetooth Button: 步骤 1 中的图像 1,1
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Bluetooth Button Replacement: 步骤 2 中的图像 1,1
    • Use the screwdriver to unscrew two 3.6mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Bluetooth Button Replacement: 步骤 3 中的图像 1,1
    • Remove the ribbon cable from the circuit board.
  4. Sol Republic Deck Bluetooth Button Replacement: 步骤 4 中的图像 1,1
    • Plug in de-soldering kit and wait 3 minutes for the solder to heat up.
    • Use the tip of your soldering iron to heat the old solder unit and apply until it melts.
    • Remove speaker wires connecting the speaker to the circuit board.
  5. Sol Republic Deck Bluetooth Button Replacement: 步骤 5 中的图像 1,1
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
  6. Sol Republic Deck Bluetooth Button Replacement: 步骤 6 中的图像 1,1
    • Unscrew fifteen 6.2mm Phillips #0 screws and lift the black plastic plate from the case.
  7. Sol Republic Deck Bluetooth Button Replacement: 步骤 7 中的图像 1,2 Sol Republic Deck Bluetooth Button Replacement: 步骤 7 中的图像 2,2
    • Remove the three 3.6mm Phillips #0 screws.
    • Remove the circuit board containing the BlueTooth button.
结论
另外一个人完成了本指南。
Jonathan Holtman
于03/20/17注册
368 声望
创作了2篇指南
团队
IUPUI, Team S3-G1, Baechle Spring 2017 IUPUI, Team S3-G1, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S3G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 546
