简介
This guide will walk you through the process of replacing your broken, dead, or dying battery in your Motorola X Sol Republic Deck.
你所需要的
With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
在这个步骤中使用的工具:Tweezers$4.99
Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
The ribbon cables are adhesive attached to the case, use tweezers to VERY carefully pick them up. They will then lift up with the circuit board. Or desolder them at the bottom to separate from the circuit board.
Melt the solder with an iron and used the tweezers to pull the wire upright.
You can pull the circuit board up and away from the wires once the wires are pointed up.
4等其他人完成本指南。
10条评论
What type of battery is it?
It's just a regular lithium ion 18650 battery 3.7v 3200-3500 mah. The deck ultra uses 2 of these
Aaron Linn - 回复
The wires which are blue and purple are connected to battery body if im not wrong
