跳转到主内容
SodaStream Fountain Jet A200 Spring Replacement
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: 步骤 1 中的图像 1,2 SodaStream Fountain Jet A200 Spring Replacement, removing back cover: 步骤 1 中的图像 2,2
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: 步骤 2 中的图像 1,2 SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: 步骤 2 中的图像 2,2
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: 步骤 3 中的图像 1,2 SodaStream Fountain Jet A200 Spring Replacement, spring removal: 步骤 3 中的图像 2,2
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
结论
5等其他人完成本指南。
2条评论
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - 回复
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 57
总计 10,073
