跳转到主内容
SodaStream Fountain Jet A200 CO2 Tube Replacement
  1. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the front cover: 步骤 1 中的图像 1,2 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the front cover: 步骤 1 中的图像 2,2
    • Locate the two prongs at the bottom of the button which releases the bottles (at the front of the machine).
    • Push both prongs down together; pull this part of the machine out towards you.
  2. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the back cover: 步骤 2 中的图像 1,2 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the back cover: 步骤 2 中的图像 2,2
    • Press in the two gray oval shaped buttons found on either side.
    • Gently pull back on the cover until it releases from the device.
    • Release the buttons and pull the back completely off.
  3. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the Carbonation button: 步骤 3 中的图像 1,2 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the Carbonation button: 步骤 3 中的图像 2,2
    • Place your hand under the carbonation button and pull up and away from you, towards the back of the machine.
    • Warning: be careful not to pull too hard on the carbonation button; there is a spring under this button that can become loose.
  4. SodaStream Fountain Jet A200 CO2 Tube Replacement, Tightening caps on tubes: 步骤 4 中的图像 1,2 SodaStream Fountain Jet A200 CO2 Tube Replacement, Tightening caps on tubes: 步骤 4 中的图像 2,2
    • Under the carbonation button, at the end of the slim black tube will be a white cap, turn the cap in a counter clock wise motion to remove.
    • Locate the second white cap, on the front of the machine. Reattach both white caps by turning them in a clockwise direction, ensuring they are on tight.
  5. SodaStream Fountain Jet A200 CO2 Tube Replacement, Putting machine back together: 步骤 5 中的图像 1,1
    • Line up the prongs on the front cover with those on the machine and gently push until in place.
结论
8等其他人完成本指南。
8条评论
Where do you find that black tube with the white caps on the internet. My white cap broke and can't find the replacement part.
Craig V - 回复
mine broke too. plastic nut split in half. probably from chill of CO2 expansion.
where to get replacement part?
brockybeek - 回复
I’m trying to find this nut and tube everywhere. any idea where we can purcase it? or the size and pitch of the nuts au tube?
Michel Bastien - 回复
that makes four of us— where’s the tubing available??
jess youngquest - 回复
Sodastream refuses to sell parts. Maybe get a non working one on eBay for parts.
jimmylasvegas - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 28
过去 30 天: 146
总计 16,197
