本指南有最近更改,您可查看未经巡查的最新版本。
简介
The purpose of this guide is to show you how to remove/replace all of the straps on your bindings. However, you do not need to remove the toe straps to replace the ankle straps and vice versa. Begin this repair guide at the appropriate step relevant to your problem.
你所需要的
Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding.
Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding.
另外一个人完成了本指南。
