当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
The highback plate is the vertical support plate located on the heel side of the binding.
Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
Lift or slide the binding off the board and set the screws aside.
取消:我没有完成这个指南。
2等其他人完成本指南。
与4其他贡献者
于01/14/14注册
118 声望
撰写一个指南
徽章: 11
+ 8更多徽章
CPSU-FORTE-W14S17G4
5 名成员
创作了9篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 77
总计 13,417
