跳转到主内容
Snapfon ez One Microphone Replacement
你所需要的
  1. Snapfon ez One Microphone Replacement, Remove the battery cover: 步骤 1 中的图像 1,1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One Microphone Replacement, Remove the battery: 步骤 2 中的图像 1,1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One Microphone Replacement, Removing the plastic inserts: 步骤 3 中的图像 1,2 Snapfon ez One Microphone Replacement, Removing the plastic inserts: 步骤 3 中的图像 2,2
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfon ez One Microphone Replacement, Remove the shield screws: 步骤 4 中的图像 1,3 Snapfon ez One Microphone Replacement, Remove the shield screws: 步骤 4 中的图像 2,3 Snapfon ez One Microphone Replacement, Remove the shield screws: 步骤 4 中的图像 3,3
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfon ez One Microphone Replacement, Separate the case: 步骤 5 中的图像 1,3 Snapfon ez One Microphone Replacement, Separate the case: 步骤 5 中的图像 2,3 Snapfon ez One Microphone Replacement, Separate the case: 步骤 5 中的图像 3,3
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfon ez One Microphone Replacement, Remove the volume slider: 步骤 6 中的图像 1,1
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfon ez One Microphone Replacement, Remove the motherboard: 步骤 7 中的图像 1,3 Snapfon ez One Microphone Replacement, Remove the motherboard: 步骤 7 中的图像 2,3 Snapfon ez One Microphone Replacement, Remove the motherboard: 步骤 7 中的图像 3,3
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfon ez One Microphone Replacement, Microphone: 步骤 8 中的图像 1,1
    • Locate the microphone on the back of the circuit board.
  9. Snapfon ez One Microphone Replacement: 步骤 9 中的图像 1,2 Snapfon ez One Microphone Replacement: 步骤 9 中的图像 2,2
    • Desolder the microphone from the circuit board using the soldering iron.
    • The solder iron creates high temperatures that may cause bodily harm.
    • Take the replacement microphone and melt the wires to the circuit board with the soldering iron in the same fashion that the old microphone was oriented.
结论
John Bender
于03/26/14注册
818 声望
创作了8篇指南
团队
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G5
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 388
