跳转到主内容
Snapfōn ezONE LCD Screen Replacement
你所需要的
  1. Snapfōn ezONE LCD Screen Replacement, Remove the battery cover: 步骤 1 中的图像 1,1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfōn ezONE LCD Screen Replacement, Remove the battery: 步骤 2 中的图像 1,1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: 步骤 3 中的图像 1,2 Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: 步骤 4 中的图像 1,3 Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: 步骤 4 中的图像 2,3 Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: 步骤 4 中的图像 3,3
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfōn ezONE LCD Screen Replacement, Separate the case: 步骤 5 中的图像 1,3 Snapfōn ezONE LCD Screen Replacement, Separate the case: 步骤 5 中的图像 2,3 Snapfōn ezONE LCD Screen Replacement, Separate the case: 步骤 5 中的图像 3,3
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfōn ezONE LCD Screen Replacement, Remove the volume slider: 步骤 6 中的图像 1,1
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: 步骤 7 中的图像 1,3 Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: 步骤 7 中的图像 2,3 Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: 步骤 7 中的图像 3,3
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfōn ezONE LCD Screen Replacement, Pry the screen back: 步骤 8 中的图像 1,3 Snapfōn ezONE LCD Screen Replacement, Pry the screen back: 步骤 8 中的图像 2,3 Snapfōn ezONE LCD Screen Replacement, Pry the screen back: 步骤 8 中的图像 3,3
    • Pry the LCD screen off of the circuit board using the opening tool. The screen is connected to the motherboard with light adhesive, which is easy to remove.
    • The LCD screen will still be connected to the circuit board by a ribbon cable.
  9. Snapfōn ezONE LCD Screen Replacement, Disconnect the display: 步骤 9 中的图像 1,1
    • Use a soldering iron to melt away the connection between the ribbon cable and circuit board.
    • Be careful! High temperatures from the soldering iron may result in injury.
    • Only make contact with the solder connection so that none of the phone’s components are damaged by the heat.
  10. Snapfōn ezONE LCD Screen Replacement, Remove the display: 步骤 10 中的图像 1,2 Snapfōn ezONE LCD Screen Replacement, Remove the display: 步骤 10 中的图像 2,2
    • Once you heat the solder connection, lightly tug the ribbon cable free. The LCD screen will be completely removed from the device.
结论
To reassemble your device with a new LCD screen, follow these instructions in reverse order.
Note: you will need to use the soldering iron again to attach the new LCD screen ribbon to the circuit board.
另外一个人完成了本指南。
John Bender
于03/26/14注册
818 声望
创作了8篇指南
团队
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G5
3 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 543
