跳转到主内容
Smith-Corona Standard Portable Ribbon Replacement
你所需要的
  1. Smith-Corona Standard Portable Ribbon Replacement, Ribbon: 步骤 1 中的图像 1,3 Smith-Corona Standard Portable Ribbon Replacement, Ribbon: 步骤 1 中的图像 2,3 Smith-Corona Standard Portable Ribbon Replacement, Ribbon: 步骤 1 中的图像 3,3
    • Remove the cover plate.
    • The post-1931 "flat-top" model cover plate will lift up like the hood of a car, rather than being removable.
  2. Smith-Corona Standard Portable Ribbon Replacement: 步骤 2 中的图像 1,3 Smith-Corona Standard Portable Ribbon Replacement: 步骤 2 中的图像 2,3 Smith-Corona Standard Portable Ribbon Replacement: 步骤 2 中的图像 3,3
    • Un-thread the ribbon from the reverse actuator corresponding with each spool.
    • The reverse actuators can be moved inwards to give easier access to un-thread.
  3. Smith-Corona Standard Portable Ribbon Replacement: 步骤 3 中的图像 1,3 Smith-Corona Standard Portable Ribbon Replacement: 步骤 3 中的图像 2,3 Smith-Corona Standard Portable Ribbon Replacement: 步骤 3 中的图像 3,3
    • Un-thread and remove the ribbon from the ribbon vibrator.
  4. Smith-Corona Standard Portable Ribbon Replacement: 步骤 4 中的图像 1,3 Smith-Corona Standard Portable Ribbon Replacement: 步骤 4 中的图像 2,3 Smith-Corona Standard Portable Ribbon Replacement: 步骤 4 中的图像 3,3
    • Remove both spools by lifting straight up.
  5. Smith-Corona Standard Portable Ribbon Replacement: 步骤 5 中的图像 1,3 Smith-Corona Standard Portable Ribbon Replacement: 步骤 5 中的图像 2,3 Smith-Corona Standard Portable Ribbon Replacement: 步骤 5 中的图像 3,3
    • Insert the new spools into the spool holders.
    • For a two-color ribbon, make sure the black half of the ribbon is on top and red on the bottom.
  6. Smith-Corona Standard Portable Ribbon Replacement: 步骤 6 中的图像 1,2 Smith-Corona Standard Portable Ribbon Replacement: 步骤 6 中的图像 2,2
    • Position the ribbon behind the ribbon vibrator.
  7. Smith-Corona Standard Portable Ribbon Replacement: 步骤 7 中的图像 1,3 Smith-Corona Standard Portable Ribbon Replacement: 步骤 7 中的图像 2,3 Smith-Corona Standard Portable Ribbon Replacement: 步骤 7 中的图像 3,3
    • Thread the ribbon into the ribbon vibrator.
  8. Smith-Corona Standard Portable Ribbon Replacement: 步骤 8 中的图像 1,2 Smith-Corona Standard Portable Ribbon Replacement: 步骤 8 中的图像 2,2
    • Thread the ribbon through each of the reverse actuators.
    • The reverse actuators can be moved inwards to give easier access to thread.
  9. Smith-Corona Standard Portable Ribbon Replacement: 步骤 9 中的图像 1,1
    • Ensure the ribbon is moving from the fullest spool to the emptiest as you type.
    • For example, if the spool on the right is the emptiest, make sure the right-hand spool is rotating clockwise, and vice versa for the left-hand spool.
    • If the ribbon is moving in the wrong direction, flip the ribbon reverse switch.
结论
Install the cover plate by placing the rear of the cover against the body first, and in reverse to step number 1.
6等其他人完成本指南。
2条评论
My smith corona vintage typewriter ribbon won't advance. The left side is tight. The ratchet is not turning the bar. The square spring is not broken.The bar does go back and forth, better on the right side. I don't know how to lubricate the spindle shaft on the left side to make it turn more easily. The little ratchet is not grabbing as well as it might, and thus the bar is not turning. I can turn the bar with my fingers.
Jody - 回复
You're going to have to disassemble the body as much you can to get to the spool assembly and attack it with mineral spirits/rubbing alcohol to dissolve the gunk around the gears. Apply a small amount of gun oil. Typical issue for some typewriters.
Nicholas Homonko -
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 53
过去 30 天: 192
总计 10,156
